Einleitung
After removing the back cover and battery, follow this guide in order to remove the screen from the device.
Was du brauchst
Place the GPS with the screen facing down.
Remove the four 4.2 mm screws on the back cover of the device using a Phillips #0 screwdriver.
Remove the two 4.2mm screws at the bottom of the device using a Phillips #0 screwdriver.
Insert the black spudger into the crease in the side of the GPS.
Move the end of the spudger down to break the seal between the two plastic shells.
Continue doing this along each side of the GPS to ensure a smooth removal.
Fully separate the two sides of the case.
Remove the tape on the battery wires and the tape on the speaker wires.
Use the black spudger to break the seal between the adhesive and battery. Use the same spudger to continue to pry the battery from the backing
Lift the battery from the device
Once the battery is free from the adhesive, remove the piece of tape with a pair of tweezers that is covering the connection of the battery to the motherboard.
Unplug the battery from the mother board by pulling back the clips and pulling the wires away from the motherboards receptacle
Using two hands, pull back the tabs holding the screen in place.
Use a spudger to help use leverage to remove the screen, if necessary
Raise the switch locking the ribbon cable in place.
Using twesers, pull the ribbon cable from the socket.
With the ribbon cable removed, the screen is completely disconnected from the device.
To replace the ribbon cable, press the two tabs to push the head into the socket.
