Zum Hauptinhalt wechseln
Magellan RoadMate 2120T-LM Speaker Replacement
Was du brauchst
  1. Magellan RoadMate 2120T-LM Speaker Replacement, Battery: Schritt 1, Bild 1 von 3 Magellan RoadMate 2120T-LM Speaker Replacement, Battery: Schritt 1, Bild 2 von 3 Magellan RoadMate 2120T-LM Speaker Replacement, Battery: Schritt 1, Bild 3 von 3
    • Turn the GPS over on its backside and remove the six 3 mm Phillips #1 screws.
  2. Magellan RoadMate 2120T-LM Speaker Replacement: Schritt 2, Bild 1 von 2 Magellan RoadMate 2120T-LM Speaker Replacement: Schritt 2, Bild 2 von 2
    • Pry up on back panel with black spudger
  3. Magellan RoadMate 2120T-LM Speaker Replacement: Schritt 3, Bild 1 von 1
    • Disconnect battery and speaker cables from the motherboard at indicated places.
  4. Magellan RoadMate 2120T-LM Speaker Replacement: Schritt 4, Bild 1 von 1
    • Use a spudger to remove the battery from the back panel.
    • If at all possible, please try to use a regular nylon spudger before resorting to a metal spudger. Metal spudgers are much sharper, and have the potential to accidentally pierce the battery.
    • There is a strong adhesive holding the battery to the back panel.
    • This step is not a prerequisite for replacement of other components.
  5. Magellan RoadMate 2120T-LM Speaker Replacement, Speaker: Schritt 5, Bild 1 von 2 Magellan RoadMate 2120T-LM Speaker Replacement, Speaker: Schritt 5, Bild 2 von 2
    • Locate the internal speaker just above the battery
    • Remove the two 3 mm Phillips #1 screws.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 129
