Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
The back cover of the device keeps all the components safe from damage and must be removed for any component to be replaced in the device. The back cover is held on by screws and is very easy to remove.
  1. Power off the Magellan RoadMate before beginning. Remove the six 5mm Phillips #00  screws from the back of device. Remove the six 5mm Phillips #00  screws from the back of device.
    • Power off the Magellan RoadMate before beginning.
    • Remove the six 5mm Phillips #00 screws from the back of device.
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard. Do not fully open the back cover or you risk damaging the speaker wire. Use a spudger to disconnect the speaker connection from the motherboard.
    • Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
    • Do not fully open the back cover or you risk damaging the speaker wire.
    • Use a spudger to disconnect the speaker connection from the motherboard.
Abschluss
Chris Blaskowski
370 Reputation
3 Anleitungen geschrieben
IUPUI, Team 4-4, Wilson Fall 2016 Mitglied von IUPUI, Team 4-4, Wilson Fall 2016
IUPUI-WILSON-F16S4G4
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 82
