Einleitung
Rechargeable batteries eventually degrade and lose their ability to hold a charge. Once this happens, the only fix is to replace the battery. Ensure that your device is powered off before beginning this step.
Was du brauchst
Pry back cover off with a plastic opening tool just enough to see where the speaker is attached to the motherboard.
Use a spudger to disconnect the speaker connection from the motherboard.
Run the tip of a spudger between the battery and the housing to loosen the double-sided tape holding the battery in.
Still using the spudger tool, pry the battery from the housing.
Pull the edge of the tape up to remove the tape that holds the battery wire to the motherboard.
Slowly pull the connection from the motherboard.
