Zum Hauptinhalt wechseln
Magellan RoadMate 5236T-LM Display Screen Replacement
Was du brauchst
  1. Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: Schritt 1, Bild 1 von 3 Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: Schritt 1, Bild 2 von 3 Magellan RoadMate 5236T-LM Display Screen Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Place the device face down on a flat surface.
    • Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
  2. Magellan RoadMate 5236T-LM Display Screen Replacement: Schritt 2, Bild 1 von 3 Magellan RoadMate 5236T-LM Display Screen Replacement: Schritt 2, Bild 2 von 3 Magellan RoadMate 5236T-LM Display Screen Replacement: Schritt 2, Bild 3 von 3
    • Gently wedge a plastic opening tool into the seam along the side of the device.
    • Slide the tool along the seam to pry apart the front and back covers.
  3. Magellan RoadMate 5236T-LM Display Screen Replacement: Schritt 3, Bild 1 von 2 Magellan RoadMate 5236T-LM Display Screen Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • A ribbon cable attaches the display screen and the motherboard via a ZIF connector. Remove the tape covering where the ZIF connector connects to the mother board.
    • Use tweezers to disconnect the ZIF connector from the motherboard.
    • The ZIF connector may disconnect itself from the motherboard when removing the tape.
  4. Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: Schritt 4, Bild 1 von 3 Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: Schritt 4, Bild 2 von 3 Magellan RoadMate 5236T-LM Display Screen Replacement, Display Screen: Schritt 4, Bild 3 von 3
    • Place the front panel on a flat surface, screen side down.
    • Using a plastic opening tool, apply light lifting pressure to each of the 6 casing clips to release the screen from the plastic casing.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 4-7, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 4-7, Catania Fall 2016
UMASSD-CATANIA-F16S4G7
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
This would have been even a GREATER POST if, would have included the part number for the replacement screen,
But,
Just good information as to how to remove the damaged screen.
1975PINTOBOBSTER
1975PINTOBOBSTER - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 586
