Einleitung
This guide will walk you through the step-by-step instructions on how to remove and replace a Magellan RoadMate 5250T-LM display.
Was du brauchst
Holding the device in place, remove all four 5 mm screws from the back of the device using a Philips Head #000 screwdriver.
Place screws aside. Make sure they are easily accessible for reassembling the device.
Peel back the tape securing the display connector to the motherboard.
Use a nylon spudger to flip up the black tab on the ZIF connector.
Pull the ribbon cable out with tweezers.
Undo the four clamps holding down the display.
Remove the display from the front cover.
