Einleitung
This guide will walk you through the step-by-step instructions on how to remove and replace a Magellan RoadMate 5250T-LM display.
Was du brauchst
Holding the device in place, remove all four 5 mm screws from the back of the device using a Philips Head #000 screwdriver.
Place screws aside. Make sure they are easily accessible for reassembling the device.
Undo the four clamps holding down the display.
Remove the display from the front cover.
