Einleitung
You can change the motherboard of the device by following this guide. When disconnecting the mother board , try to unplug all the wires carefully. Using more force can damaged the wires clips or wires it self.
Was du brauchst
Unscrew four screws in the top left corner by using Phillips #0 size screwdriver.
Unplug the wires by pushing it down and slowly pulling it towards you.
After unplugging the wires, take the motherboard out.
