Zum Hauptinhalt wechseln
Magellan Roadmate 9055-LM Power Button Replacement
Was du brauchst
  1. Magellan Roadmate 9055-LM Power Button Replacement, Magellan Roadmate 9055-LM Back Panel Disassembly: Schritt 1, Bild 1 von 1
    • Flip your device with back panel facing up.
  2. Magellan Roadmate 9055-LM Power Button Replacement: Schritt 2, Bild 1 von 3 Magellan Roadmate 9055-LM Power Button Replacement: Schritt 2, Bild 2 von 3 Magellan Roadmate 9055-LM Power Button Replacement: Schritt 2, Bild 3 von 3
    • Unscrew four Phillips #0 screws from the back panel.
  3. Magellan Roadmate 9055-LM Power Button Replacement: Schritt 3, Bild 1 von 2 Magellan Roadmate 9055-LM Power Button Replacement: Schritt 3, Bild 2 von 2
    • Unscrew two Phillips #0 screws from the back panel.
  4. Magellan Roadmate 9055-LM Power Button Replacement: Schritt 4, Bild 1 von 2 Magellan Roadmate 9055-LM Power Button Replacement: Schritt 4, Bild 2 von 2
    • Use a plastic opening tool to pop the right side of the panel.
  5. Magellan Roadmate 9055-LM Power Button Replacement: Schritt 5, Bild 1 von 1
    • Lifting the back panel too quickly or forcefully may damage the speaker cable and battery cable, which are still attached underneath.
    • Gently lift up the back panel.
  6. Magellan Roadmate 9055-LM Power Button Replacement: Schritt 6, Bild 1 von 3 Magellan Roadmate 9055-LM Power Button Replacement: Schritt 6, Bild 2 von 3 Magellan Roadmate 9055-LM Power Button Replacement: Schritt 6, Bild 3 von 3
    • Remove the tape.
    • Unplug the cable for the speaker.
  7. Magellan Roadmate 9055-LM Power Button Replacement: Schritt 7, Bild 1 von 3 Magellan Roadmate 9055-LM Power Button Replacement: Schritt 7, Bild 2 von 3 Magellan Roadmate 9055-LM Power Button Replacement: Schritt 7, Bild 3 von 3
    • Remove the cable of the battery.
    • Tape removal is not necessary.
  8. Magellan Roadmate 9055-LM Power Button Replacement: Schritt 8, Bild 1 von 1
    • Place the back panel gently on the table.
  9. Magellan Roadmate 9055-LM Power Button Replacement, Power Button: Schritt 9, Bild 1 von 1
    • After the back panel is placed on the table, you must need to locate the starting button.
  10. Magellan Roadmate 9055-LM Power Button Replacement: Schritt 10, Bild 1 von 1
    • It is easily removable and can now be replaced.
Abschluss
Giovanni
313 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 1-5, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 1-5, Catania Fall 2016
UMASSD-CATANIA-F16S1G5
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 119
