Einleitung
Are you having trouble getting your Magic Bullet to turn on? Are the plastic activator tabs on your Magic Bullet broken off? This guide will help you replace the activators.
Was du brauchst
Use pliers to grip the gear inside of the top of the device.
Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
Remove the three 11.0 mm Phillips head screws surrounding the white fan blade on the base using the Phillips #1 screwdriver.
Remove the three 11.0 mm Phillips head screws using the Phillips #1 screwdriver.
Wedge a flathead screwdriver in between the casing and white plastic activator.
Pry the white plastic activators from the casing as needed.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
You gotta be kidding me?
Where would you get replacement activators or spring beneath these? How much would that cost?
