Zum Hauptinhalt wechseln
Magic Bullet MB1001B Power Cord Replacement
Was du brauchst
  1. Magic Bullet MB1001B Power Cord Replacement, Power Cord: Schritt 1, Bild 1 von 1
    • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
  2. Magic Bullet MB1001B Power Cord Replacement: Schritt 2, Bild 1 von 1
    • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
  3. Magic Bullet MB1001B Power Cord Replacement: Schritt 3, Bild 1 von 1
    • Remove the black base plate.
  4. Magic Bullet MB1001B Power Cord Replacement: Schritt 4, Bild 1 von 1
    • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
  5. Magic Bullet MB1001B Power Cord Replacement: Schritt 5, Bild 1 von 1
    • Remove the white plastic cable guide.
  6. Magic Bullet MB1001B Power Cord Replacement: Schritt 6, Bild 1 von 1
    • Remove the two crimp caps from the end of the wires.
    • You will need to purchase new crimp caps and use pliers to crimp the new crimp caps on the connected wires during reassembly.
  7. Magic Bullet MB1001B Power Cord Replacement: Schritt 7, Bild 1 von 1
    • Separate the black wires of the power cord from the red wires on the Magic Bullet base.
    • Be sure to mark which wires are connected before separating them to ensure that they are properly reconnected during reassembly.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 12-13, Maness Fall 2015 Mitglied von Cal Poly, Team 12-13, Maness Fall 2015
CPSU-MANESS-F15S12G13
4 Mitglieder
8 Anleitungen geschrieben
2 Kommentare
I accidentally burnt through my power cord. What type of power cord do I need to replace it?
virginia.cooke - Antwort
Where do we get a new power cord, and if that does not work, what do we do next?
davidcohnkettlebells - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 34
Insgesamt: 2,384
