Einleitung
The exterior component of the NutriBullet’s powerbase consist of a silver, plastic shell casing. Use this guide to replace the cylindrical shell to ensure no leakage, exposure of wires or spinning components are showing through.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Use a #2 Phillips Head Screwdriver to unscrew the four 10 mm screws located on the bottom of the power base.
Use slight tension to remove the plastic base from the NutriBullet once all of the screws are removed.
Use a #2 Phillips Head Screwdriver to remove the two 10 mm screws that secure the white bracket down.
Use a #2 Phillips Head Screwdriver to remove the three 10mm screws that keep the base in place.
Use slight tension to remove the curved base by lifting it upward off of the outside casing.
Wiggle the outside casing upward until it separates from the powerbase.
2 weitere Nutzer haben diese Anleitung absolviert.
