Einleitung
Did your device leak liquid? Do it seem to not seal as well as before? Replace the gasket to create a new seal and prevent leaking from your cup.
Was du brauchst
Using tweezers, grab the gasket at the indented lip which is located on the side of the blending blade.
Slowly pry the rubber gasket up.
Eine weitere Person hat diese Anleitung absolviert.
10 Kommentare
The trouble is, this process doesn't work in reverse order as the gasket keeps popping up where you are not applying the pressure. You could do this all day and I'm sure it would be great therapy for OCD.
I want to replace the rubber gasket. My trouble is I can't find a gasket that states it will fit this model. magic Bullet NUTRIBULLET model number NB-WL007-02 Can you tell me where to purchase this? Thanks!
Marcia Sikes
today_first@cox.net
My understanding is that if it's leaking all the way into the base and not out the sides, it's likely not the main gasket (a faulty one of these would probably cause it to leak out the sides). This is a really good video that explains how to remove the blade and replace the washers that act as gaskets to stop liquid from dripping straight through the center/blade area.
lizzywad is correct. The %#*@ thing wont stay in, it keeps popping out. What else can be done?
The gasket in the Nutribullet has disappeared and I think it was blended into the fruit and veg . I drank half of it before I discovered it. I cannot find out if it is toxic or not. Geraldine
