Zum Hauptinhalt wechseln
Magna Outreach Rear tire Replacement
Was du brauchst
  1. Magna Outreach Rear tire Replacement, Rear Tire: Schritt 1, Bild 1 von 1
    • Disconnect the rear brake cable
  2. Magna Outreach Rear tire Replacement: Schritt 2, Bild 1 von 1
    • Flip the bike over so that it is resting on the seat and handlebars.
    • Use an adjustable wrench to remove the nuts on both sides of the wheel that hold the wheel to the frame.
    • Lift the tire away from the frame and chain.
  3. Magna Outreach Rear tire Replacement: Schritt 3, Bild 1 von 1
    • Insert one tire lever under the tire and hook it onto a spoke. Insert the other tire lever next to the first and slide it along the rim to remove one side of the tire from the rim.
  4. Magna Outreach Rear tire Replacement: Schritt 4, Bild 1 von 1
    • Starting at the valve, pull the inner tube out of the gap between the rim and the tire.
  5. Magna Outreach Rear tire Replacement: Schritt 5, Bild 1 von 1
    • Pull the tire away from the rim.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 1-14, Donnelly Fall 2014 Mitglied von USF Tampa, Team 1-14, Donnelly Fall 2014
USFT-DONNELLY-F14S1G14
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 2,485
