Was du brauchst
Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
Use a Phillips #2 screwdriver to remove the two screws at the base of the disk drive.
Use the screwdriver to remove two screws on either side of the silver security bar.
Fast fertig!
Abschluss
