Zum Hauptinhalt wechseln
Magnavox MWD200F Disk Drive Replacement
Was du brauchst
  1. Magnavox MWD200F Disk Drive Replacement, Faceplate: Schritt 1, Bild 1 von 1
    • Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
  2. Magnavox MWD200F Disk Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
  3. Magnavox MWD200F Disk Drive Replacement: Schritt 3, Bild 1 von 1
    • Unclip the three latches on the bottom of the device.
  4. Magnavox MWD200F Disk Drive Replacement: Schritt 4, Bild 1 von 1
    • Pull the faceplate off.
  5. Magnavox MWD200F Disk Drive Replacement, Disk Drive: Schritt 5, Bild 1 von 2 Magnavox MWD200F Disk Drive Replacement, Disk Drive: Schritt 5, Bild 2 von 2
    • Use a Phillips #2 screwdriver to remove the two screws at the base of the disk drive.
  6. Magnavox MWD200F Disk Drive Replacement: Schritt 6, Bild 1 von 2 Magnavox MWD200F Disk Drive Replacement: Schritt 6, Bild 2 von 2
    • Use the screwdriver to remove two screws on either side of the silver security bar.
  7. Magnavox MWD200F Disk Drive Replacement: Schritt 7, Bild 1 von 2 Magnavox MWD200F Disk Drive Replacement: Schritt 7, Bild 2 von 2
    • Pull out the silver security bar and set aside.
  8. Magnavox MWD200F Disk Drive Replacement: Schritt 8, Bild 1 von 1
    • Take out the two screws on either side of the green circuit board.
  9. Magnavox MWD200F Disk Drive Replacement: Schritt 9, Bild 1 von 2 Magnavox MWD200F Disk Drive Replacement: Schritt 9, Bild 2 von 2
    • Carefully lift the board just enough to remove the disk drive.
  10. Magnavox MWD200F Disk Drive Replacement: Schritt 10, Bild 1 von 3 Magnavox MWD200F Disk Drive Replacement: Schritt 10, Bild 2 von 3 Magnavox MWD200F Disk Drive Replacement: Schritt 10, Bild 3 von 3
    • Remove the two screws at the back of the disk drive.
  11. Magnavox MWD200F Disk Drive Replacement: Schritt 11, Bild 1 von 2 Magnavox MWD200F Disk Drive Replacement: Schritt 11, Bild 2 von 2
    • Gently lift the disk drive out of the DVD player.
    • The disk drive is still attached but you are now able to get to underneath it for cleaning and maintenance.
Abschluss
Taryn
109 Reputation
4 Anleitungen geschrieben
University of Maine, Team 1-2, Diaz Fall 2011 Mitglied von University of Maine, Team 1-2, Diaz Fall 2011
UMAINE-DIAZ-F11S1G2
2 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,490
