Einleitung
If you have message "Camera failed"
First of all try this: Open Camera app from the "Application manager" and do "Clear data", then restart the phone.
Second: Do a Factory reset (of course save your data!).
Third: Reinstall Android OS.
If this not help you, you have a hardware problem. You need to change the camera.
Also you can test the camera from the Hidden / Test menu. Enter this code at the dealer: *#0*#
See also: Samsung Galaxy S4 Rückkamera austauschen
Was du brauchst
Einführungsvideo
Use the flat end of a spudger to disconnect the rear-facing camera connector.
Using tweezers, or your fingers, slide the rear-facing camera out of its notch in the motherboard.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
