Einleitung
This guide will walk you through the process of replacing the rear axle in a Maisto Rock Crawler.
Was du brauchst
Flip the R/C truck over.
To take off the R/C truck top, use the driver and bit PH2 and remove the four 7.7 mm Phillips screws highlighted.
Half way remove the truck top so you can unhinge the antenna from the clips.
Remove the R/C truck top completely.
Use the Driver and bit J1 to remove the top under-body plate by unscrewing the eight 9.5 mm Phillips screws.
After removing the plate use the driver and bit J1 to unscrew the two 9.5 mm Phillips screws that hold the side circuit board in.
Flip the R/C truck over and remove the four 10 mm bottom under-body plate screws using the driver and bit PH2.
You can refer to the tire replacement guide to keep salvageable tires from the removed axle.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
Nice guide. Do you know where to buy parts for the repairment? I have searched all over but cannot seem to find any parts.
