Einleitung
This guide will walk you through the process of replacing the truck circuit board in a Maisto Rock Crawler.
Was du brauchst
Flip the R/C truck over.
To take off the R/C truck top, use the driver and bit PH2 and remove the four 7.7mm Philips screws highlighted.
Half way remove the truck top so you can unhinge the antenna from the clips.
Remove the R/C truck top completely.
Use the Driver and bit J1 to remove the top under-body plate by unscrewing the eight 9.5mm Philips screws.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
9 Kommentare
My rc car is not responding to left or right signals from remote.
CAN I got any help on this
Can any one help as my rc rock crawler is not turning left or right
did you use biger voltage than normal? because it sound like that. i think your’s car has brokened ic-component.
