Zum Hauptinhalt wechseln
Makita DT01 Battery Replacement
  1. Makita DT01 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Makita DT01 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Makita DT01 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Lay the device down on its side.
  2. Makita DT01 Battery Replacement: Schritt 2, Bild 1 von 1
    • Pinch the indents on both sides of the battery.
  3. Makita DT01 Battery Replacement: Schritt 3, Bild 1 von 1
    • Pull the battery out of the drill
    • Recharge or completely replace the battery
    • Make sure that the battery is removed before further working on the drill. This is so the drill doesn't accidentally activate.
Abschluss
Victoria Scira
226 Reputation
2 Anleitungen geschrieben
Ein Kommentar
Replacement for Makita DT01 Power Tool Battery
Type: Li-ion
Volt: 10.8V
Capacity: 3000mAh
Color: Black
Weight: 166g
Dimension: 50.75 x 50.20 x 77.80mm
You can contact this seller for a lower price if you want a quantity purchase of Makita DT01 replacement batteries on https://www.drill-battery.net.au/buybatt...
Drillbatterycomau - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 522
