Zum Hauptinhalt wechseln
Makita DT01 LED light replacment
Was du brauchst
  1. Makita DT01 LED light replacment, LED light: Schritt 1, Bild 1 von 2 Makita DT01 LED light replacment, LED light: Schritt 1, Bild 2 von 2
    • Take out the battery.
    • Unscrew the six screws in the top of the drill.
  2. Makita DT01 LED light replacment: Schritt 2, Bild 1 von 1
    • Motor and trigger should be separated.
    • The LED cable should be taken out from the trigger.
  3. Makita DT01 LED light replacment: Schritt 3, Bild 1 von 1
    • Take out the plastic tape that is stacked on the LED light.
    • Take out the two cables that are connecting with the LED light.
    • Reconnect the two cables again with the new LED light.
Abschluss
Ya'Rub Al Manwari
201 Reputation
2 Anleitungen geschrieben
Ein Kommentar
Where can I buy the replacement led?
Ciaran Moss - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 325
