Einleitung
This guide will show you how to replace the grease in your angle grinder should it become dirty and fail to lubricate the gears.
Was du brauchst
Check for the provided lock nut wrench. This is used for loosening the piece that keeps the disk and cover attached.
Hold the black switch located on the front casing.
Still holding the switch, use the lock nut wrench to loosen the silver disk holding everything in place.
Once loose, remove the silver disk and/or your grinding disk.
Use a Phillips #02 screwdriver to remove the 15 mm pan head screw that holds the cover in place.
Remove the cover by lining up the knob on the cover with the notch in face plate.
Unscrew the four 15 mm pan head screws using a Phillips #02 screwdriver.
Remove the face of the device. You may need to jiggle it a little to get it off.
Blow compressed air into the device to make sure it is completely clean.
Squeeze in enough grease to fill the indents inside of the cavity.
Use a metal spudger to spread the grease evenly across the face of the device.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
Hi, what is the recommended grease?
Hi. You’re great.
Can I use white lithium grease. Thanks my brushes appear to about half an inch long if the grease doesn’t work going to try them????
Angle grinders use a PAO lithium soap grease. Most use Nye Lubricants RheoLube 380, which is hard to source or expensive to buy.
You may substitute with Dupont Molykote G4700 grease. ereplacementParts.com has the Nye grease.
Hi, I’m trying to replace the spindle of my ga4030 with the one from the ga4530, to effectively make it into a 4-1/2” model. Looking at the parts list for both of these grinders, it appears they are identical except for the spindle, disc retaining nuts, and wheel shroud/guard. Do you know if this mod is possible? It looks like I would just need to remove that small bearing that’s pressed on to the top of the spindle.
