Einleitung
This guide outlines the replacement of the internal electrical switch.
Was du brauchst
Unscrew the 20 mm tapping screw using a Phillips #02 screwdriver.
Lift the clasp up and out to remove.
Place your finger in the gap in front of the switch. Now, at the base of the device, push the switch lever into the 'on' position.
Pull back the plastic clip and pull the internal switch up and out of the cavity.
Remove the two 10 mm screws holding the power cord leads in place using a Phillips #02 screwdriver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
