Einleitung
This guide will show you the necessary steps to locate and replace the forward/reverse switch. It shows how to remove the battery and the outer casing in order to locate the forward/reverse switch of the drill.
Was du brauchst
Hold the drill upright.
Place your finger on the white battery-release button.
Slide the battery forward while pressing down on the white battery-release button.
Hold the drill upright with the back panel facing you.
Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
Apply slight pressure to the sides of the backplate and pull away from the drill.
Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
Apply slight pressure to the sides of the outer casing and pull away from the drill.
Pull the silver metal clip located towards the back of the motor assembly away from the drill.
Grip the motor comfortably towards the front of the assembly, and pull it away from the outer casing.
Eine weitere Person hat diese Anleitung absolviert.
