Einleitung
The drill contains two drill brushes. This guide will show you the necessary steps to locate and replace both drill brushes. It shows how to remove the battery and back panel to locate the drill brushes.
Ersatzteile
Keine Ersatzteile angegeben.
Hold the drill upright.
Place your finger on the white battery-release button.
Slide the battery forward while pressing down on the white battery-release button.
Apply slight pressure to the sides of the backplate and pull away from the drill.
Hold the drill so the back end is facing toward you.
Use the spudger to lift the spring clip out of the back notch.
Pull the spring clip forward and rest it in the front notch.
Use the plastic opening tool to release the clip connected to the drill brush.
Separate the drill brush away from the clip.
3 weitere Nutzer haben diese Anleitung absolviert.
2 Kommentare
To find excellent replacement Makita power tool batteries. Australia Drill Battery Shop offers the lowest price and high quality cordless drill battery for Makita. All our cordless drill batteries are guaranteed to meet or exceed OEM(original). http://www.drillbattery.com.au/batteryst...
Mehr Infos gibr’s hier >> https://makita-set.bernaunet.com
