Zum Hauptinhalt wechseln
Makita XPH01 LED Light Replacement
Was du brauchst
  1. Makita XPH01 LED Light Replacement, Battery: Schritt 1, Bild 1 von 1
    • Hold the drill upright.
    • Place your finger on the white battery-release button.
  2. Makita XPH01 LED Light Replacement: Schritt 2, Bild 1 von 1
    • Press and hold the white release button located on the front of the battery.
  3. Makita XPH01 LED Light Replacement: Schritt 3, Bild 1 von 1
    • Slide the battery forward while pressing down on the white battery-release button.
  4. Makita XPH01 LED Light Replacement, Outer Casing: Schritt 4, Bild 1 von 2 Makita XPH01 LED Light Replacement, Outer Casing: Schritt 4, Bild 2 von 2
    • Hold the drill upright with the back panel facing you.
    • Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
  5. Makita XPH01 LED Light Replacement: Schritt 5, Bild 1 von 1
    • Apply slight pressure to the sides of the backplate and pull away from the drill.
  6. Makita XPH01 LED Light Replacement: Schritt 6, Bild 1 von 2 Makita XPH01 LED Light Replacement: Schritt 6, Bild 2 von 2
    • Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
  7. Makita XPH01 LED Light Replacement: Schritt 7, Bild 1 von 2 Makita XPH01 LED Light Replacement: Schritt 7, Bild 2 von 2
    • Apply slight pressure to the sides of the outer casing and pull away from the drill.
  8. Makita XPH01 LED Light Replacement, LED Light: Schritt 8, Bild 1 von 2 Makita XPH01 LED Light Replacement, LED Light: Schritt 8, Bild 2 von 2
    • Use the pointed end of a plastic spudger to push the LED out of the drill.
  9. Makita XPH01 LED Light Replacement: Schritt 9, Bild 1 von 2 Makita XPH01 LED Light Replacement: Schritt 9, Bild 2 von 2
    • Use the pointed edge of a spudger to pull out the black and white wires located on the left hand side of the drill.
    • Use the pointed edge of a spudger to pull out the plastic connector.
  10. Makita XPH01 LED Light Replacement: Schritt 10, Bild 1 von 3 Makita XPH01 LED Light Replacement: Schritt 10, Bild 2 von 3 Makita XPH01 LED Light Replacement: Schritt 10, Bild 3 von 3
    • Use the flat end of the spudger to push in the clip on the plastic connector.
    • Pull both sides of the plastic connector apart.
  11. Makita XPH01 LED Light Replacement: Schritt 11, Bild 1 von 3 Makita XPH01 LED Light Replacement: Schritt 11, Bild 2 von 3 Makita XPH01 LED Light Replacement: Schritt 11, Bild 3 von 3
    • Pull the silver metal clip on the motor away from the drill.
  12. Makita XPH01 LED Light Replacement: Schritt 12, Bild 1 von 1
    • Pull the black trigger assembly away from the drill.
  13. Makita XPH01 LED Light Replacement: Schritt 13, Bild 1 von 2 Makita XPH01 LED Light Replacement: Schritt 13, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to pull out the LED light assembly.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Eric Herwatt
984 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 15-4, Livingston Fall 2016 Mitglied von Cal Poly, Team 15-4, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G4
4 Mitglieder
Ein Kommentar
Should I do these steps if my drill is under a warranty?
Richard Williams - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 41
Insgesamt: 2,473
