Einleitung
The outer casing of the drill needs to be taken out in order to replace the other parts of the drill. There are a total of nine 18 mm screws that needs to be taken out of the outer casing. This guide serves as a prerequisite guide for the other replacement guides.
Was du brauchst
Hold the drill upright.
Place your finger on the white battery-release button.
Slide the battery forward while pressing down on the white battery-release button.
Hold the drill upright with the back panel facing you.
Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
Apply slight pressure to the sides of the backplate and pull away from the drill.
Unscrew the nine 18 mm screws from the outer casing using a Phillips PH2 screwdriver.
Apply slight pressure to the sides of the outer casing and pull away from the drill.
