Zum Hauptinhalt wechseln
Marshal Woburn Top Control Panel Replacement
Was du brauchst
  1. Marshal Woburn Top Control Panel Replacement, Back Panel: Schritt 1, Bild 1 von 2 Marshal Woburn Top Control Panel Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
    • On a flat surface, orient the device so that the front grille is facing downward.
    • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
    • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
  2. Marshal Woburn Top Control Panel Replacement: Schritt 2, Bild 1 von 2 Marshal Woburn Top Control Panel Replacement: Schritt 2, Bild 2 von 2
    • Lift the back input board slightly above the back panel.
    • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
    • Fully slide the input board through the back panel and set it down gently inside the speaker.
  3. Marshal Woburn Top Control Panel Replacement: Schritt 3, Bild 1 von 1
    • Grab the panel by the large hole and lift one side until you can fit your hand under.
    • Use your hand to fully remove the back panel from the rest of the frame.
  4. Marshal Woburn Top Control Panel Replacement, I/O Board: Schritt 4, Bild 1 von 1
    • Disconnect the 5 wires circled in red from the back input board.
    • There may be a little resistance when pulling on the wires, but it should not require excessive force.
  5. Marshal Woburn Top Control Panel Replacement: Schritt 5, Bild 1 von 2 Marshal Woburn Top Control Panel Replacement: Schritt 5, Bild 2 von 2
    • Remove the two 12.7 mm screws marked in red from the front of the back input panel with a Phillips #1 screwdriver.
    • Remove the power input from the back side of the panel.
  6. Marshal Woburn Top Control Panel Replacement: Schritt 6, Bild 1 von 1
    • Completely remove the I/O board and the attached plate.
  7. Marshal Woburn Top Control Panel Replacement, Top Control Panel: Schritt 7, Bild 1 von 1
    • Using a Philips #1 screwdriver, remove the eight 9.5 mm screws that are marked in red from the perimeter of the metal frame for the top control panel.
  8. Marshal Woburn Top Control Panel Replacement: Schritt 8, Bild 1 von 1
    • From the outside of the speaker, push down on the top control panel until you can feel the adhesive holding it to the frame start to loosen.
    • On the inside, make your way around the border of the top control panel and remove the adhesive until you can fully remove the panel from the frame.
Abschluss
NateP
281 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 Mitglied von UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 22
Insgesamt: 138
