Zum Hauptinhalt wechseln
Marshall Emberton Battery Replacement
Was du brauchst
  1. Marshall Emberton Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the rubber casing from the speaker using your nails to peel the cover off.
    Frag FixBot
    Kommentar hinzufügen
  2. Marshall Emberton Battery Replacement: Schritt 2, Bild 1 von 1
    • Pry out both covers that are on the front and backside of the speaker to reveal the screws to get inside the speaker.
    Frag FixBot
  3. Marshall Emberton Battery Replacement: Schritt 3, Bild 1 von 2 Marshall Emberton Battery Replacement: Schritt 3, Bild 2 von 2
    • Use a TR9 screwdriver to remove the eight 1.2 cm screws.
    • Use a spudger or opening tool to pry out the speakers.
    Frag FixBot
  4. Marshall Emberton Battery Replacement: Schritt 4, Bild 1 von 1
    • Use a TR9 screwdriver to remove the six 1 cm screws that secure the motherboard.
    Frag FixBot
  5. Marshall Emberton Battery Replacement: Schritt 5, Bild 1 von 2 Marshall Emberton Battery Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the three wire connectors marked, by firmly tugging on the wire.
    Frag FixBot
  6. Marshall Emberton Battery Replacement: Schritt 6, Bild 1 von 1
    • Use TR9 screwdriver to remove the final two 1.2 cm screws that secure the battery.
    Frag FixBot
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
CSU Los Angeles, Team 5-1, Adachi Fall 2022 Mitglied von CSU Los Angeles, Team 5-1, Adachi Fall 2022
CSULA-ADACHI-F22S5G1
5 Mitglieder
6 Anleitungen geschrieben
5 Kommentare zur Anleitung
Add any tools at the top you used in this repair guide and also any replacement parts if you can.
Yamilena Hernandez - Antwort Teilen
How can i buy battery
Rubel hussain - Antwort Teilen
How can I buy the battery
Sreenath Ps - Antwort Teilen
How to buy a battery for my emberton?
MADHANRAJ MURUGESAN - Antwort Teilen
From where to buy battery? What is the battery specification?
Hasin Shahriar - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 16
Letzte 7 Tage: 96
Letzte 30 Tage: 473
Insgesamt: 19,324
