Zum Hauptinhalt wechseln
Marshall Emberton Button Replacement
Was du brauchst
  1. Marshall Emberton Button Replacement, Button: Schritt 1, Bild 1 von 1
    • Remove the rubber casing from the speaker by peeling it off using your nails.
    Frag FixBot
    Kommentar hinzufügen
  2. Marshall Emberton Button Replacement: Schritt 2, Bild 1 von 1
    • Use a TR9 screwdriver to remove the eight 1 cm screws located on top of the speaker.
    Frag FixBot
  3. Marshall Emberton Button Replacement: Schritt 3, Bild 1 von 1
    • Once all the screws are off, you must pry the plastic piece off using any tool capable of sliding into the crevice. Then easily pop the piece out.
    Frag FixBot
  4. Marshall Emberton Button Replacement: Schritt 4, Bild 1 von 1
    • On the back side of the plastic piece, there is a circuit which is shown in the picture. Use a TR9 screwdriver to remove two 1.2 cm screws to detach the circuit from the plastic housing.
    Frag FixBot
  5. Marshall Emberton Button Replacement: Schritt 5, Bild 1 von 1
    • Once the circuit is removed, you may gently pop the button off and easily replace it with a new one.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
CSU Los Angeles, Team 5-1, Adachi Fall 2022 Mitglied von CSU Los Angeles, Team 5-1, Adachi Fall 2022
CSULA-ADACHI-F22S5G1
5 Mitglieder
6 Anleitungen geschrieben
4 Kommentare zur Anleitung
where can i find a replacement button
MANU 1907 - Antwort Teilen
The worst instruction I've ever seen in my life. If you do this, you will break your device.
cool eo - Antwort Teilen
yes, i confirme !!!
Mallet Jp - Antwort Teilen
@cooleo fortunately i figured it out but yeah you ned to disassemble multiple parts. disassemble from the front panel (marshal logo panel is pressure fit, undo the phillips, and take the board out behind it, and then take out the top out + switch.
Daniel Hyunsu Kim - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 14
Letzte 7 Tage: 49
Letzte 30 Tage: 205
Insgesamt: 4,174
