Zum Hauptinhalt wechseln
Marshall Emberton Main Speaker Replacement
Was du brauchst
  1. Marshall Emberton Main Speaker Replacement, Main Speaker: Schritt 1, Bild 1 von 1
    • Remove the rubber casing from the speaker by peeling it off using your nails.
  2. Marshall Emberton Main Speaker Replacement: Schritt 2, Bild 1 von 1
    • Pry the front of the speaker that says "Marshall" in order to get inside the speaker.
  3. Marshall Emberton Main Speaker Replacement: Schritt 3, Bild 1 von 1
    • Remove the eight 1.2 cm screws using a TR9 screwdriver.
  4. Marshall Emberton Main Speaker Replacement: Schritt 4, Bild 1 von 1
    • Now pop the speaker out and remove the entire piece.
  5. Marshall Emberton Main Speaker Replacement: Schritt 5, Bild 1 von 1
    • Now you must disconnect two wire connectors, by firmly tugging on the wires.
    • The new speakers can now be connected and put back together.
Abschluss
Asia Baldwin
697 Reputation
5 Anleitungen geschrieben
CSU Los Angeles, Team 5-1, Adachi Fall 2022 Mitglied von CSU Los Angeles, Team 5-1, Adachi Fall 2022
CSULA-ADACHI-F22S5G1
5 Mitglieder
Ein Kommentar
Hi! Where from can I by the speakers? pls help
Cristian MUNTEANU - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 23
Letzte 30 Tage: 106
Insgesamt: 2,389
