Einleitung
The Marshall Emberton has two main speakers which are on the front and backside of the speaker. These speakers produce quality bass and sound. Like any other speaker, the audio eventually loses it’s power.
With the help of this guide, you will be able to replace both main speakers. Replacing these speakers requires a TR-9 screwdriver.
Was du brauchst
Remove the rubber casing from the speaker by peeling it off using your nails.
Pry the front of the speaker that says "Marshall" in order to get inside the speaker.
Now you must disconnect two wire connectors, by firmly tugging on the wires.
The new speakers can now be connected and put back together.
1 Kommentar zur Anleitung
Hi! Where from can I by the speakers? pls help
