Einleitung
The rechargeable battery used in this device is one of the components most likely to fail. Fortunately the replacement process is simple and straightforward. Follow this guide for a pain-free battery replacement experience.
Was du brauchst
Place the unit face down as shown in the picture, exposing the battery cover.
Remove the two 4.0mm long screws holding the cover on using a T10 driver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
This one should work: https://vintrons.com/products/marshall-t...
Hi, does anybody know how to recharge the battery external, because something on the platina fried (LL10) component, and it want charge through the killburn, but works fine with battery. Thank you
