Zum Hauptinhalt wechseln
Marshall Woburn I/O Board Replacement
Was du brauchst
  1. Marshall Woburn I/O Board Replacement, Back Panel: Schritt 1, Bild 1 von 2 Marshall Woburn I/O Board Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
    • On a flat surface, orient the device so that the front grille is facing downward.
    • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
    • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
  2. Marshall Woburn I/O Board Replacement: Schritt 2, Bild 1 von 2 Marshall Woburn I/O Board Replacement: Schritt 2, Bild 2 von 2
    • Lift the back input board slightly above the back panel.
    • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
    • Fully slide the input board through the back panel and set it down gently inside the speaker.
  3. Marshall Woburn I/O Board Replacement: Schritt 3, Bild 1 von 1
    • Grab the panel by the large hole and lift one side until you can fit your hand under.
    • Use your hand to fully remove the back panel from the rest of the frame.
  4. Marshall Woburn I/O Board Replacement, I/O Board: Schritt 4, Bild 1 von 1
    • Disconnect the 5 wires circled in red from the back input board.
    • There may be a little resistance when pulling on the wires, but it should not require excessive force.
  5. Marshall Woburn I/O Board Replacement: Schritt 5, Bild 1 von 2 Marshall Woburn I/O Board Replacement: Schritt 5, Bild 2 von 2
    • Remove the two 12.7 mm screws marked in red from the front of the back input panel with a Phillips #1 screwdriver.
    • Remove the power input from the back side of the panel.
  6. Marshall Woburn I/O Board Replacement: Schritt 6, Bild 1 von 1
    • Completely remove the I/O board and the attached plate.
Abschluss
Ryan Berry
237 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 Mitglied von UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G4
3 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
what is step 7? Replace the board? PS. I was born in N Dartmouth!
Mary F Boston - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 54
Insgesamt: 362
