Zum Hauptinhalt wechseln
Martian Victory Watch band Replacement
Was du brauchst
  1. Martian Victory Watch band Replacement, Watch band: Schritt 1, Bild 1 von 1
    • Take the watch band removal tool and insert it in the small slit between watch bezel and the band, resting up against the bezel.
  2. Martian Victory Watch band Replacement: Schritt 2, Bild 1 von 1
    • Press down of the shaft that holds the band on, while simultaneously dragging the tip of the tool back towards the band in order to compress the spring bar that holds the band on.
    • Drag the tip of the tool away from the bezel while still pressing down in order to remove the shaft from the bezel.
    • The spring shaft may decompress once its out of the bezel and try to shoot away.
  3. Martian Victory Watch band Replacement: Schritt 3, Bild 1 von 1
    • Repeat these steps on the other side of the band to completely remove the band, ready for cleaning or replacement.
Abschluss
IUPUI, Team 3-3, Baechle Fall 2016 Mitglied von IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 278
