Einleitung
This guide explains all the steps for taking apart the device, taking out the old auxiliary port from the device and soldering on a new one. This guide requires basic soldering knowledge and if done improperly may cause injury to the user. People with physical hand or wrist disabilities be cautioned that you may need to consider asking someone else to replace the part for you so you do not injure yourself.
Was du brauchst
Remove two of the three screws shown on the bottom of the device.
Begin removing the last screw, but leave it partially in the socket to remove the bottom cover easier.
Remove the bottom cover by either pulling on the screw or using a plastic opening tool to pry the cover off.
After removing the bottom cover, remove the two screws.
Use a spudger to release the small retaining clip that holds the feet to the bottom of the device.
Remove the two screws from the back of the device.
Using a plastic opening tool and your hand, separate the front and back covers from each other.
Starting from the bottom, use the plastic opening tool to create the initial separation and continue along the seam to the top of the device.
Remove the two arms from either side of the device once a significant separation has been created.
Continue pulling the back cover off the device.
Remove the red cover for the on/off switch from the device.
Remove the two screws shown to release the circuitboard.
Gently remove both the battery and circuitboard.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Locate the auxiliary port on the top side of the circuitboard.
On the bottom of the circuitboard, locate the metal pin connecting the auxiliary port to the circuitboard.
Use the soldering iron to disconnect the pin.
Use a pair of tweezers to remove the old auxiliary port.
Place the new auxiliary port in the same spot and solder the port to the circuitboard.
