Einleitung
This guide will demonstrate how to access and replace the power switch cover of the Marvel iHome MR-M66.
Was du brauchst
Remove two of the three screws shown on the bottom of the device.
Begin removing the last screw, but leave it partially in the socket to remove the bottom cover easier.
Remove the bottom cover by either pulling on the screw or using a plastic opening tool to pry the cover off.
After removing the bottom cover, remove the two screws.
Use a spudger to release the small retaining clip that holds the feet to the bottom of the device.
Remove the two screws from the back of the device.
Using a plastic opening tool and your hand, separate the front and back covers from each other.
Starting from the bottom, use the plastic opening tool to create the initial separation and continue along the seam to the top of the device.
Remove the two arms from either side of the device once a significant separation has been created.
Continue pulling the back cover off the device.
Remove the red cover for the on/off switch from the device.
