Einleitung
A battery replacement will be inevitable with any toy, and this T-Rex is no exception. For this repair, you need 3 cell batteries (and maybe tweezers to help remove them), as well as a JIS #1 screwdriver.
Was du brauchst
Turn the dinosaur with the belly facing up, and unscrew the 9.6 mm JIS #1 screw.
Using the tweezers if necessary, remove the cell batteries from the dinosaur.
To reassemble your device, follow these instructions in reverse order, using new cell batteries.
