Zum Hauptinhalt wechseln
Matsunichi MarquisPad MP977 Battery Replacement
Was du brauchst
  1. Matsunichi MarquisPad MP977 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the two screws using a Phillips #00 screwdriver.
  2. Matsunichi MarquisPad MP977 Battery Replacement: Schritt 2, Bild 1 von 3 Matsunichi MarquisPad MP977 Battery Replacement: Schritt 2, Bild 2 von 3 Matsunichi MarquisPad MP977 Battery Replacement: Schritt 2, Bild 3 von 3
    • Place the device face down on a flat surface.
    • Insert one of the wide-tipped, plastic opening tools into the top of the left speaker slot.
    • Be sure to avoid puncturing the covering of the speaker.
    • Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and its back plate until you reach the power button.
  3. Matsunichi MarquisPad MP977 Battery Replacement: Schritt 3, Bild 1 von 2 Matsunichi MarquisPad MP977 Battery Replacement: Schritt 3, Bild 2 von 2
    • Insert the opening tool into the right speaker slot.
    • Pry open the back plate, and slide the tool counterclockwise along the device until you reach the charging port.
  4. Matsunichi MarquisPad MP977 Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the back plate and place it to the side.
  5. Matsunichi MarquisPad MP977 Battery Replacement: Schritt 5, Bild 1 von 2 Matsunichi MarquisPad MP977 Battery Replacement: Schritt 5, Bild 2 von 2
    • Detach the battery from the motherboard.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015 Mitglied von UMass Dartmouth, Team 4-1, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G1
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 1,533
