Was du brauchst
Using the PH #00 Phillips head screwdriver, unscrew the two screws.
Place the device face down on a flat surface.
Insert the wide-tipped plastic opening tool into the top of the left speaker slot.
Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and the back plate until you reach the power button.
Insert the opening tool into the slot located to the right of the speaker, at the top edge of the device.
Then, pry open the back plate of the device , and slide the tool counter clockwise along the device until you reach the charging port.
With the same screw driver, PH #00 Phillips head, remove the seven screws holding in the motherboard.
Gently pull the camera optic fiber out of it's slot to release the flap. This will allow the flap to open easily.
