Was du brauchst
Remove the two screws using a PH #00 Phillips head screw driver.
Place the device face down on a flat surface.
Insert one of the wide tipped, plastic opening tools into the top of the left speaker slot.
Pry the back plate open and slide the tool in a clockwise direction, moving it along the opening between the device and its back plate until you reach the power button.
Insert opening tool into the right speaker slot.
Pry open the back plate, and slide the tool counter clockwise along the device until you reach the charging port.
Remove the screws holding the metal frame plate in place.
Remove the metal frame plate from the plastic housing.
Eine weitere Person hat diese Anleitung absolviert.
