Einleitung
This guide describes how to replace the arms that position the propellers for the Mavic 2 drone.
Was du brauchst
Remove the two M2x5 screws from the plastic cover by the camera using and H1.5 Allen bit.
Gently remove the cover by the front camera by wiggling out the clips holding it in on both sides.
Remove the six M2x5 screws from the bottom plastic cover using a H1.5 Allen bit.
Remove the plastic cover once all screws are extracted.
Using tweezers or a plastic pick, remove either the white or black wire plugging into the board.
Remove all ten M2x5 mm screws holding the top plastic cover of the drone. Two at the back, four in the battery bay, and two at each front arm joint.
Use a Phillips #0 screwdriver to remove the screw that secures the arm spring.
Then remove the spring, use either tweezers or a flat-head screwdriver to lift it up out of the arm.
On the topside of the drone,desolder the wires from the main board that correspond to the arm trying to be replaced, there should be six in total.
Remove the arm once all wires are desoldered.
Eine weitere Person hat diese Anleitung absolviert.
