Zum Hauptinhalt wechseln
Mavic 2 Main Board Replacement
Was du brauchst
  1. Mavic 2 Main Board  Replacement, Remove screws: Schritt 1, Bild 1 von 1
    • Begin to remove screws from belly of drone.
  2. Mavic 2 Main Board  Replacement, Continue to remove screws: Schritt 2, Bild 1 von 3 Mavic 2 Main Board  Replacement, Continue to remove screws: Schritt 2, Bild 2 von 3 Mavic 2 Main Board  Replacement, Continue to remove screws: Schritt 2, Bild 3 von 3
    • remove the rest of the screws
  3. Mavic 2 Main Board  Replacement: Schritt 3, Bild 1 von 2 Mavic 2 Main Board  Replacement: Schritt 3, Bild 2 von 2
    • After all 8 Screws are removed. Remove the back panel. Keep in mind there is a ribbon connecting the panel and the main board. You must detach the ribbon from either side.
  4. Mavic 2 Main Board  Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the screws holding the board in place, as well as all the ribbons and antennas connecting the board to the frame.
  5. Mavic 2 Main Board  Replacement: Schritt 5, Bild 1 von 1
    • Then remove the old board. Replace the new board you have and repeat the process in reverse.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team S15-G3, Barthe Fall 2019 Mitglied von UMass Dartmouth, Team S15-G3, Barthe Fall 2019
UMASSD-BARTHE-F19S15G3
1 Mitglied
1 Anleitung geschrieben
Ein Kommentar
Hello sir,
I have a question and I hope to find the answer
The plane (Mavic 2) collided with a pilot turned into a pole, and after that, I find a stutter in the camera from time to time, so I hope to find a way to solve this problem since the camera works, the camera shake.
Amr Ahmed - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 26
Insgesamt: 1,457
