Einleitung
This guide will show you how to disassemble a Maxi-Matic Intertek popcorn maker (model EPM-1810BL; series number 25322) by removing its inner circuitry. Before starting, make sure the popper is turned off, unplugged, and cool.
Was du brauchst
Turn the air popper upside down.
Remove the screw above the label with a #2x4" screwdriver.
Remove the screw under the label with the Y1 screwdriver head from the iFixit ProTechToolkit.
Turn the air popper back over (right side up). Remove the plastic protection piece from the top of the air popper.
Remove the two screws using a #2x4" screwdriver.
Remove the black lid.
Unscrew the ring around the central cylinder using the Phillips #2 screwdriver and a wrench or pliers to hold the bolt in place.
Remove the central cylinder by pulling it out straight upwards.
Remove these two screws using a #2x4" screwdriver.
Remove the wide, short cylinder from the interior by pulling and separating it from the disk inside it, taking the cylinder fully out.
Use a plastic iFixit prying tool to remove the switch from the main body.
Disconnect the blue and red wires from the switch.
Use a plastic iFixit prying tool to remove the cord attachment from the main body of the air popper.
Remove the entire circuit from the device.
To reassemble the device, follow these instructions in reverse order.
