Zum Hauptinhalt wechseln
Mayflash Arcade Stick F300 Joystick Replacement
Was du brauchst
  1. Mayflash Arcade Stick F300 Joystick Replacement, Metal Backplate: Schritt 1, Bild 1 von 3 Mayflash Arcade Stick F300 Joystick Replacement, Metal Backplate: Schritt 1, Bild 2 von 3 Mayflash Arcade Stick F300 Joystick Replacement, Metal Backplate: Schritt 1, Bild 3 von 3
    • Flip the controller upside down so that the metal panel is facing you.
    • Remove the six 11 mm screws securing the metal panel using a Phillips #2 screwdriver.
    • Once all screws are removed, lift off the panel.
    Frag FixBot
  2. Mayflash Arcade Stick F300 Joystick Replacement, Joystick: Schritt 2, Bild 1 von 2 Mayflash Arcade Stick F300 Joystick Replacement, Joystick: Schritt 2, Bild 2 von 2
    • Detach the micro switch cables connected to the PCB (printed circuit board).
    Frag FixBot
  3. Mayflash Arcade Stick F300 Joystick Replacement: Schritt 3, Bild 1 von 3 Mayflash Arcade Stick F300 Joystick Replacement: Schritt 3, Bild 2 von 3 Mayflash Arcade Stick F300 Joystick Replacement: Schritt 3, Bild 3 von 3
    • Use a flathead screwdriver to hold the bottom screw of the joystick lever in place.
    • Flip the device over.
    • Grab the ball top of the joystick and twist while the screwdriver prevents the screw from turning.
    • Once the ball top is removed, slide off the plastic tube and plate from the joystick.
    Frag FixBot
  4. Mayflash Arcade Stick F300 Joystick Replacement: Schritt 4, Bild 1 von 3 Mayflash Arcade Stick F300 Joystick Replacement: Schritt 4, Bild 2 von 3 Mayflash Arcade Stick F300 Joystick Replacement: Schritt 4, Bild 3 von 3
    • Flip the device over again, exposing the inside.
    • Use a Phillips #1 screwdriver to remove the four screws holding down the joystick lever.
    • Slide the joystick out of the outer plastic casing.
    Frag FixBot
Abschluss
Utah Tech University, Team 1-4, Crenshaw Fall 2024 Mitglied von Utah Tech University, Team 1-4, Crenshaw Fall 2024
UTAHTECH-CRENSHAW-F24S1G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 60
Insgesamt: 818
