Zum Hauptinhalt wechseln
Mayflash Arcade Stick F300 Microswitch Replacement
Was du brauchst
  1. Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: Schritt 1, Bild 1 von 3 Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: Schritt 1, Bild 2 von 3 Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: Schritt 1, Bild 3 von 3
    • Flip the controller upside down so that the metal panel is facing you.
    • Remove the six 11 mm screws securing the metal panel using a Phillips #2 screwdriver.
    • Once all screws are removed, lift off the panel.
  2. Mayflash Arcade Stick F300 Microswitch Replacement, Microswitch: Schritt 2, Bild 1 von 2 Mayflash Arcade Stick F300 Microswitch Replacement, Microswitch: Schritt 2, Bild 2 von 2
    • Remove the four 9 mm truss head screws fastening the clear plastic square joystick gate to the casing underneath using a Phillips #1 screwdriver.
  3. Mayflash Arcade Stick F300 Microswitch Replacement: Schritt 3, Bild 1 von 3 Mayflash Arcade Stick F300 Microswitch Replacement: Schritt 3, Bild 2 von 3 Mayflash Arcade Stick F300 Microswitch Replacement: Schritt 3, Bild 3 von 3
    • Gently push back on each of the four black locking tabs securing the joystick gate to the casing.
    • Remove the joystick gate.
  4. Mayflash Arcade Stick F300 Microswitch Replacement: Schritt 4, Bild 1 von 2 Mayflash Arcade Stick F300 Microswitch Replacement: Schritt 4, Bild 2 von 2
    • Lift the chosen microswitch vertically off the rod holding it in position.
    • Desolder the wire from the terminal (metal connection point).
    • Beware of overheating the soldering kit as it can damage electronic components.
    • Use a wire stripper or small blade to strip the insulation approximately 1 cm from the end of the wire before resoldering to the new part.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Saul Aguiar
290 Reputation
2 Anleitungen geschrieben
Utah Tech University, Team 1-4, Crenshaw Fall 2024 Mitglied von Utah Tech University, Team 1-4, Crenshaw Fall 2024
UTAHTECH-CRENSHAW-F24S1G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 43
Insgesamt: 118
