Zum Hauptinhalt wechseln
Mayflash Arcade Stick F300 USB Cable Replacement
Was du brauchst
  1. Mayflash Arcade Stick F300 USB Cable Replacement, Metal Backplate: Schritt 1, Bild 1 von 3 Mayflash Arcade Stick F300 USB Cable Replacement, Metal Backplate: Schritt 1, Bild 2 von 3 Mayflash Arcade Stick F300 USB Cable Replacement, Metal Backplate: Schritt 1, Bild 3 von 3
    • Flip the controller upside down so that the metal panel is facing you.
    • Remove the six 11 mm screws securing the metal panel using a Phillips #2 screwdriver.
    • Once all screws are removed, lift off the panel.
    Frag FixBot
  2. Mayflash Arcade Stick F300 USB Cable Replacement, USB Cable: Schritt 2, Bild 1 von 2 Mayflash Arcade Stick F300 USB Cable Replacement, USB Cable: Schritt 2, Bild 2 von 2
    • Remove the four 10 mm truss head screws securing the PCB to the plastic outer casing using a Phillips #1 screwdriver.
    Frag FixBot
  3. Mayflash Arcade Stick F300 USB Cable Replacement: Schritt 3, Bild 1 von 3 Mayflash Arcade Stick F300 USB Cable Replacement: Schritt 3, Bild 2 von 3 Mayflash Arcade Stick F300 USB Cable Replacement: Schritt 3, Bild 3 von 3
    • Use a hair dryer or heat gun to soften the glue holding the USB cable into the socket on the PCB.
    • It should take less than a minute for the glue to be soft enough to remove. Do not overheat the circuit board.
    • Use a metal spudger to gently remove the softened glue.
    • Remove the cable from the socket
    Frag FixBot
  4. Mayflash Arcade Stick F300 USB Cable Replacement: Schritt 4, Bild 1 von 3 Mayflash Arcade Stick F300 USB Cable Replacement: Schritt 4, Bild 2 von 3 Mayflash Arcade Stick F300 USB Cable Replacement: Schritt 4, Bild 3 von 3
    • Slide the strain relief segment of the USB cable out of the plastic outer casing.
    • Remove the cable.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Utah Tech University, Team 1-4, Crenshaw Fall 2024 Mitglied von Utah Tech University, Team 1-4, Crenshaw Fall 2024
UTAHTECH-CRENSHAW-F24S1G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 29
Insgesamt: 528
