Zum Hauptinhalt wechseln
Maylong M-270 Motherboard Replacement
Was du brauchst
  1. Maylong M-270 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 2 Maylong M-270 Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Use the plastic opening tool to separate the back cover plate from the front.
    • Insert the plastic opening tool in between the back plate cover and the top cover, then slide along edges to pry open.
  2. Maylong M-270 Motherboard Replacement: Schritt 2, Bild 1 von 2 Maylong M-270 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Locate the two ribbons attached to the device's motherboard.
    • Flip the small black plastic catches down by using the small end of the spudger.
    • Remove the ribbons by gently pulling them away from the motherboard.
  3. Maylong M-270 Motherboard Replacement: Schritt 3, Bild 1 von 2 Maylong M-270 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Remove the two screws from the motherboard.
    • Remove the four screws and metal holds from the edge of the device.
  4. Maylong M-270 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the motherboard by gently pulling it away from the bottom of the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Adam Sanders
222 Reputation
2 Anleitungen geschrieben
University of Alabama, Team 1-3, Naidoo Spring 2015 Mitglied von University of Alabama, Team 1-3, Naidoo Spring 2015
UA-NAIDOO-S15S1G3
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 529
