Was du brauchst
Use the plastic opening tool to separate the back cover plate from the front.
Insert the plastic opening tool in between the back plate cover and the top cover, then slide along edges to pry open.
Locate the two ribbons attached to the device's motherboard.
Flip the small black plastic catches down by using the small end of the spudger.
Remove the ribbons by gently pulling them away from the motherboard.
Remove the two screws from the motherboard.
Remove the four screws and metal holds from the edge of the device.
Remove the motherboard by gently pulling it away from the bottom of the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
