Zum Hauptinhalt wechseln
Maylong MN-1000P Battery Replacement
Was du brauchst
  1. Maylong MN-1000P Battery Replacement, Bottom Cover: Schritt 1, Bild 1 von 1
    • Place the netbook top down, with the opening of the netbook facing you.
  2. Maylong MN-1000P Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the six 6mm Phillips #00 screws from the netbook.
  3. Maylong MN-1000P Battery Replacement: Schritt 3, Bild 1 von 3 Maylong MN-1000P Battery Replacement: Schritt 3, Bild 2 von 3 Maylong MN-1000P Battery Replacement: Schritt 3, Bild 3 von 3
    • Remove the sticker in the middle of the netbook.
    • Remove the middle 6mm Phillips #00 screw.
  4. Maylong MN-1000P Battery Replacement: Schritt 4, Bild 1 von 1
    • Using two plastic opening tools, pry off the bottom of the netbook by going around the edges.
  5. Maylong MN-1000P Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the bottom of the netbook by lifting the corners.
  6. Maylong MN-1000P Battery Replacement, Battery: Schritt 6, Bild 1 von 2 Maylong MN-1000P Battery Replacement, Battery: Schritt 6, Bild 2 von 2
    • Pinch the red and black wires connected to the section closest to the small white connector, and pull to remove them from the motherboard.
Abschluss
katelyn buckman
553 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 185
